Orbi WiFi 7 RBE973
Reply
Configure Sync
JamesRubin
Follower
Configure Sync
This is about adding an RBS50 to my RBR50 router. It's the 4th satellite. It appears to be connected but in the Backhaul status column, instead of "Good" to describe the connection, it says Config Sync. I don't know how to do that. Pressing the sync buttons on the satellite and the router has no effect.
James
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Re: Configure Sync
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but Orbi systems are not like standard routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 3
Guru
Re: Configure Sync
Does the RBS have the same version of FW loaded as whats on the RBR? Needs to be the same version.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 584 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
