Reply
Connect external hard drive to Satellite LAN port
debrasunshine
Follower
Can an external hard drive be connected to a Satellite’s LAN port to make the drive wirelessly available on WiFi network?
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
Guru
Re: Connect external hard drive to Satellite LAN port
Does the external drive support a LAN port? if so, I would presume it works. I would contact the mfr of the drive to check what is supported.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 465 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
