- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connected but no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
On recommendations by Netgear i did a reset and new setup yesterday. Last night my tv (now on 5) during netflix streaming showed buffering 4 times, on 2.4 it never showed buffering. And this morning 2 different phones had no internet. Both phones where powered on during the night. Only after wifi off and on and a few minutes later the phones suddenly get internet again.
Additionally one laptop (Surface Book 1) had issues getting internet on 5 Ghz.
All the internet issues did not exist when the devices connect to 2.4.
So my wifi system is crap and does not work reliable on 5 ghz.
I do not want to do all kind of basic diagnose as i have done it already and on 2.4 i have no issues. I am happy to create log fikes for you. Please instruct me how to collect these log files.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connected but no internet
Would be nice if there were log files. There is a "debug" file that can be created (from the "debug" web page: //http:<orbi ip>/debug.htm), but I have no idea how to make sense of it.
Can you please clarify: At one time, your Orbi WiFi names (SSID's) were "split", where 2.4G had one name (SSID) and 5G had a different SSID. After talking to Netgear and doing a reset, is this still the case? (As far as I know, this will be a "first" for Netgear to advise a customer to create different SSID's for 2.4G and 5G. Will be exciting news on the forum!)
Alas, the community forum is just a collection of Orbi owners who (for one reason or another) have decided to participate. We have no idea what steps people have taken previously, and bring various perspectives and backgrounds. The forum is NOT "Netgear Support." Far from it. We are the people whose 90 days of free support have run out and try to find solutions collectively. I, for example, am "too cheap" to sign up for GearHead. https://gearhead.netgear.com
So far, forum participants have solve most of my problems, and I am really fortunate.
A lot of Orbi problems seem to have come up before for other owners. If we could summarize, the problem seems to be that with the new configuration, devices connect at 5G and performance is worse than when they conneced at 2.4G?
- Mark as New
- Bookmark
- Subscribe
- Permalink
On 2.4 ghz no problems. On 5 ghz i have problems with video stream and getting data after device wake up.
Good to know that this is not a Netgear website. I will raise support case with Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
NG does not support the separation or splitting of the SSID.
Has a power OFF of the ISP modem and Orbi for 30 seconds then back on with the modem first then the Orbi after that?
How about a factory rest and walk thru the Orbi setup wizard...
@Gebla wrote:
In the past i made a split into a ssid on 2.4 and a ssid to 5 ghz because i had a problem with several devices on 5 ghz. On 5 ghz devices show connected to wifi but they get no or very slow internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is the crap firmware of netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what is the distance between the RBR and RBS, specifically?
Has a factory reset and setup from scratch been performed since last update?
Please try the suggestions presented.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR and SBS are about 10 meters apart and SBS and SB are 10 meters apart. Both wired into the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the RBS directly connect to the RBR or are they connect to a LAN switch then to the RBR? What is the Mfr and model# of the ethernet switch if one is in the configuration?
Is Daisy Chain disabled?
Are you getting internet at the RBR and not the RBS or the entire system doesn't get internet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Daisy chain is enabled and I now reduced the system from 3 RBS to 1 RBS directly wired into the RBR. Still issues with 5 GHZ. Next step is moving the wired RBS into a non wired connection to the RBR and see if it will work.
Got in contact with Netgear support but they refuse warranty because I used Telnet on the devices (even after me doing factory reset support is declined). Unfortunately my experience with Netgear is now even worse. I got a bad product that does not work and they refuse warranty. Go Netgear!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disable Daisy chain if your RBS are ethernet connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this, factory reset the RBR while its disconnected from the modem. Configure your modem for router mode, not bridge mode. Configure the RBR or AP mode, after applying the change, connect the WAN port of the RBR in AP mode to the modem in router mode. Does this work?
What did you do with the RBRs telnet? I wouldn't think that would void the warranty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
With telnet i created a ssid for 2.4 and 5 to ensure that all devices connect to 2.4 and 5 is no longer used. These settings are now removed because of the factory reset. The warranty person I spoke to did not know what Telnet is but decided that i changed the product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya separation of the SSID isn't supported on Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Gebla wrote:
Changing to AP seems to resolve the difficulty to connect after wake up. .....
Do you mean that you tried to set Orbi to AP Mode and that gave you an improvement?
You mentioned earlier that you have your Ziggo router bridged, correct? If Orbi is now in AP Mode and Ziggo is bridged, which box is proving routing functionalities in your network now? 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. I did a reset of Ziggo modem/router and the Ziggo is now routing with dhcp
2. I did a reset of RBR and RBS and chbaged to AP mode
3. Last night I removed all wire backhaul from the RBR and RBS to create a wireless backhaul.
Today I will be testing this setup. If it does not work I will sent back the devices for repair.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used the satellite and router with wired backhaul and as switch (several devices hardwired into the rbr and rbs). Causing many problems on 5G
I removed all wires except for the internet connection and use the setup as AP. Now devices connect and data throughput seems more stable.
This looks like a real firmare issue. For the Netgear price it only delivers half of the functionality.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Old:
Modem into rbr, 3 wires connected to rbr. 2 of these wired directly to rbs. One rbs had 4 devices connected wired other rbs one device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the condidtion of the LAN cables between the RBR and RBS? Quality of cables could be a cause also.
CAT#? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With a normal switch? This external swithc connected between the RBR and RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Old setup with Orbi as DHCP (and with problems on 5Ghz)
Ziggo modem -> Wired -> RBR -> Wired RBS -> Wired to 4 devices
-> Wired RBS -> Wired to one device
-> Wired PC
New setup with Orbi as AP
Ziggo Modem->Wired PC
->Wired switch -> Wired to 4 devices
->Wired RBR -> Wireless RBS
-> Wireless RBS
No switch to the ORbi system.
I still have problems that sometimes data throughput stops but it deos receover now. When that happens it seems that the device is switching between access points.
