Reply
Connected devices with 1.3.0.12
th3w01f
Apprentice
I've run into an issue since upgrading to the new firmware.
1. Devices that were being recognized previously are now showing unknown.  I know it's easy enough to put a custom name but it's a PITA that I have to go back and figure out what the devices are again using the OUI.
2. I have two devices (Nest Protect and Withings scale) that are both connected to the orbi and communicating out to the internet with no issues but neiter is showing in the connected devices list.  I've verified that they are on the correct SSID and have a DHCP lease from the orbi scope.
Anyone else seeing these issues?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Re: Connected devices with 1.3.0.12
hi
yup , there are many unknown clients showing on this fw even though it was supposed to address the issue , not sure what happened there but i have reported it to the dev team
also set the attached devices list back to the way it should be
goto
orbilogin.com/debug.htm
tick the
Enable advanced view of Attached Devices page
then click save down the bottom
then go back to the attached devices list and see if that helps
pete
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2038 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
