Reply
BMcB
Follower
Connected, no internet
It's appears that my Orbi Satelitte is on with a blue light but isn't transmitting a wifi signal. I've rebooted and tested and while I get almost 300 Mbs from the router. The satelitte isn't giving me anything. All firmware is up to date. Any ideas?
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
Guru
Re: Connected, no internet
Try resetting the satellite. Hold in the reset button for 15 seconds until the top led turns on Amber. Then let go. Wait for the slow pulsating WHITE led. Then re-add to the router. If this fails, I would contact NG support and get help. Ask for an RMA if needed.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 876 views
  • 0 kudos
  • 2 in conversation
Announcements
