Darren_620's avatar
Jan 18, 2021
Connecting a 2.4G Lenovo Smart Plug (any 2.4G device) to my Orbi RBR850
Just managed to connect my 2.4G smart plugs to my Orbi for the first time and wanted to share what I did.
1. I upgrade to the latest firmware V3.2.16.22_1.4.9 (not sure if this helped but sharing everything)
2. Using orbilogin.net on my laptop I went to advanced tab and then selected the advanced option and then the "Wireless Settings"
3. I disabled the check box in the 5G section and pressed apply. (you may need to also remove the check on 20/40 under 2.4G section)
4. I then used the Lenovo App and importantly the setting required me to disconnect from mobile data and make sure my location service was turned on.
5. Following the plug setup in the App I was finally able to connect the plug to the network.
6. After adding the plugs I then selected the 5G check box turning it back on and pressed Apply
7. Went into the orbi page and saw the devices were attached and renamed them and selected the smart plug icon etc.
Finally they work on the App, Alexa etc...
1 Reply
  • FURRYe38's avatar
    What Orbi model are you referring too? Orbi AX?
    What check box are you referring to inthe 5G section?
