- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting hard disk to Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello All,
I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. I know there are different reports regarding the USb functionality on the Orbi router.
I currently have a network switch which is connected to Orbi router and many devices are connected to the switch including my ASUS router.
My question is that when I connect my HDD to the ASUS router I dont see it on the network probably coz of different IP address of different routers? or soemthing. I would like to access the hard disk on Roku and android TV which do not detect the HDD on the network.
Any solutions? help or ideas is very much appreciated
Thanks
HG
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting hard disk to Router
@hgandhi204 wrote:Hello All,
Thanks
HG
Are you still using the ASUS router with the Orbi ROUTER??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi doesn't support USB drives.
You'll have to contact ASUS to see how they support and configure there router for USB drives. I presume if your wanting to use the ASUS as your USB drive support, you may want to configure that router for AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Orbi doesn't support USB drives.
https://www.windowscentral.com/what-devices-can-you-connect-netgear-orbi-rbk50-usb-port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not officially supported by NG.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have connected my ASUS router through the network switch which gets its connection from Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I was aware of Orbi not supporting USB drives, that is why I connected my ASUS router. I used the ASUS router before Orbi and connected the drive which worked fine for 1 year. I will research about AP mode. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@hgandhi204 wrote:Yes, I was aware of Orbi not supporting USB drives, that is why I connected my ASUS router. I used the ASUS router before Orbi and connected the drive which worked fine for 1 year. I will research about AP mode. Thanks
Nice....AP mode is required IF you must run 2 routers. In most cases running 2 routers on a network can be like having 2 queen bees in the same hive. Will not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didnt understand your question? ASUS router supports HDD, thats why I connected it to network switch through orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
AP mode should work. Get with ASUS if you need to.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see. Yeah I guess I can do AP mode, as Orbi is providing internet throughout the house now. FYI my ASUS router still has SSID and if I connect to that SSID i am still getting good speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I will update here once i try it whether it worked or not. For future as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You mighy try disableing the wifi on the ASUS router and just use it as your USB drive connection point and switch. Keep the Orbi wifi as your main wifi. You can use the wifi on the ASUS if you keep the channels far appart from the Orbis wifi channels. Can be problematic if you run into problems. Just disable the wifi on the ASUS.
