Orbi WiFi 7 RBE973
Reply
Connection Drops Every 30 seconds
BiffTanner
Follower
Hello - I just set up my Orbi. Signal strength is wonderful but the connection drops every 30 seconds or so. It is very annoying.
Anything I should try before I return the product?
Thanks!
Message 1 of 2
Streak2
Master
Re: Connection Drops Every 30 seconds
Go to advanced settings and try and disable.
Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
MU-MIMO
Also, try and reduce the 2.4Ghz power from 100% down to say 50%. If that works then try and find a happy medium.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1943 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
