- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Connection Failure on Speed Test
Unfortunately, this still isn't resolved and I haven't received any new update. I discovered if you use Orbi's Web interface, there is an option to perform a speedtest that is burried under Advanced -> Setup -> QoS Setup . Unfortunately, since this relies on Netgear's connection to OOKLA, this is broken too. So, I think we can safely rule out any issue with our routers - this is a backend issue related to Netgear's connectivity with OOKLA, and the issue is present on all platforms (Android, iOS, and Web). I'll try to send the support team another e-mail tonight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Have the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Connection Failure on Speed Test AFTER 2.1.3.4
Updated to 2.1.3.4 which has fixed intermittent connection issue. Now speed test does not work from within the Orbi App. Going direct to OOKLA works fine and normal speeds.
Says, “Connection Failed - if the problem persists, try rebooting your router.” Rebooting has no effect on repairing this problem.
Is there something wrong with what I am doing or is this just a problem with 2.1.3.4.?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No, this is a NG speed servicie issue. Someone already contacted NG support and they said they are aware of it.
Did you perform a factory reset on the router after updating it?
@Coloflyer wrote:Updated to 2.1.3.4 which has fixed intermittent connection issue. Now speed test does not work from within the Orbi App. Going direct to OOKLA works fine and normal speeds.
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just wasted a few hours trying to troubleshoot failure of Ookla speedtest from Orbi app. Should have looked here first. Tested directly from desktop with no problems. Would appreciate a heads-up from Netgear when this happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Firmware version: 2.1.2.18 on both router and satellite.
Both direct router speedtest and orbi app on iphoneX speedtest still fail as of today. Speedtest direct from iphone app or PC/Mac are fine. Clearly Netgear->Ookla problem. Any update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That was great to hear but why is there still no mention about all of this on Netgears Main support page?
Still hold the opinion that Netgear as a Global Company just does not care about it's customers.
So problem still not fixed👺
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The last commenter is unfortunately correct. I've tried to obtain multiple updates, but there are none. The most I have heard is that Netgear is actively working with Ookla to resolve the problem. You wouldn think they would have been able to resolve the issue in a week, but I guess the issue must be more complicated than it seems from the outside. One interesting side effect of this issue is that if you've never setup advanced QoS on your router and want to you appear to be out of luck until the speed test works (at least via the Web admin). They require the speed test to run before you can actually get to the setup parameters. I haven't figured out a way around this. Hopefully, Netgear will be able to fix the problem soon as many of us have been impacted by this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
https://community.netgear.com/t5/Orbi/RBR50-Speed-Test-Failing/m-p/1554001/highlight/true#M28617
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad it's working now. Enjoy.
RBK50 v2.7.2.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
On orbilogin working too
It seems the problem has been fixed
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@PaulK617No, I haven't experienced any issues since the Speed Test problem was resolved. My nests, Hue, and Echos are all connected. I'm not sure what firmware you're using - is it 2.1.3.4? The reason I ask is that my Orbi never detected this update, and I had to go to the support page to download and manually apply the latest version. If you're using an older firmware, give that a try. Another thing that might be worth trying is to change the channels you're using for both 2.4 and 5.0 gHz. Maybe you're coincidentally picking up from new interference from something else. Otherwise, I'm sorry to say you might need to try to open a support ticket.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Below is the response I received from Netgear. I responded it wouldve saved may of us headaches had they mass emailed the speed test could not be conducted as they shut down that service. I'm sure my feedback was very important to them.
"Please be informed that Ookla (speed test provider) had to block Orbi requests after a flood of tests from Orbi users crashed their service.
This is the reason why the said functionality is not working from Orbi units.
We are currently working with Ookla for it to be restored the soonest possible time."
An email will be sent to you to once the service is back up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- « Previous
- 1
- 2
- Next »
