Orbi WiFi 7 RBE973
Reply
Connection Issues
jthomp30
Follower
Connection Issues
I'm having an issue when trying to connect monitor audio airplay amps to my orbi wifi. They just don't connect. I'm also having the same problem with my logitech airplay speaker ?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Connection Issues
Hello Jhomp30
Does it give you  a error or does it fail to connect? have you tried lowering the wireless channel?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1478 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
