Orbi WiFi 7 RBE973
Reply
Connection is very inconsistent (RBR40)
ransomeb94
I recently got my parents  to the get the RBR40 because they were having a lot of connection issues with our  old router. We got the RBR40 and it works fine except for me. I play games and stream on twitch. Whenever I play online games, I find  that I lose a lot of packets every 15 seconds just about and I'm not sure why.  My streaming software also goes to 0 in bitrate and then goes back up, but will go back to 0 between 15 to 20 seconds and its very annoying. Any fix?
Message 1 of 2
Guru
Re: Connection is very inconsistent (RBR40)
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 399 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
