Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
‎2019-12-12
03:31 AM
‎2019-12-12
03:31 AM
Connection of devices
Why do wifi items closest to the satellite not connect to it?
They connect back to the router with a weaker signal, is there a way to manually Manage these connections?
Thanks in anticipation 🤔
Model: RBR50|Orbi AC3000 Tri-band WiFi Router, RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
‎2019-12-12
06:45 AM
‎2019-12-12
06:45 AM
Re: Connection of devices
Most devices decide on there own on which signal to connect too.
You can reduce the power output of the RBR to help with this.
Under Advanced Tab/Advanced Settings/Wireless Settings
Try 75% or 50%.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
