Reply
Connection timed out banking websites
Nrk
On odd occasions I am not able to connect to these websites. ( Connection times out).
https://netbanking.hdfcbank.com/netbanking/
Onlinesbi.com
I have power of and power on the router twice or thrice before these sites become accessible.
I can access these sites through my mobile and through VPN.
Any thoughts
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 9
Accepted Solutions
Nrk
Re: Connection timed out banking websites
Ok doesn't seem to be a problem with the Orbi ... multiple people using the same ISP are facing the problem..
Message 8 of 9
All Replies
Guru
Is the Orbi system operating in Router or AP mode?
Only this site or do others do the same thing?
Onlinesbi.com
Any thoughts
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 9
Nrk
Orbi acts as a router.
Firmware Ver 2.3.1.58
The cable from ISP connects directly to Orbi there is no modem on premises.
Message 3 of 9
Nrk
These are the only sites where I have noticed the problem.
Message 4 of 9
Guru
IF you connect directy to the ISP services with your PC, does this still happen?
Has a factory reset and setup from scratch been performed on the RBR yet?
Testing
Message 5 of 9
Nrk
Doesn't happen when I connect directly to the ISP.
Yes reset the router and updated firmware and reconfiged the RBR
Thanks
Message 6 of 9
Guru
Try the Orbi in AP mode and see.
Does this happen with different browsers? Try IE11, Firefox or Opera...
Testing
Message 7 of 9
Nrk
Message 8 of 9
Guru
OK, the ISP will need to resolve this then. Good Luck.
Testing
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1282 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
