- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection
Can I connect the router to the modem wirelessly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection
No, it's not possible without extra wireless transmission equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection
The Orbis don't support wireless bridge mode.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
