- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Constant dropping (wired and wireless) with two wireless satellites and one wired
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been having an issue with daisy-chaining not working quite right, so I decided to hardwire one of my furthest satellites back to the RBR50 base. At first, everything was good and the hardwired satellite provided increased performance. However, a few hours later the system started dropping all over the place. Wired and wireless connections are affected.
If I turn off the hardwired satellite, things settle down and performance is fine. Why would this be?
A quick run-down of the archicture:
Orbi RBR50 is connected directly to the modem. One LAN port is connected to an 8 port Netgear switch. That switch is connected to two Netgear PoE switches (for security system). The hardwired satellite is connected to a non-PoE port on one of the PoE switches. There are no other DHCP servers on the network.
Here the Orbi gear I'm running:
RBR50
FIrmware: V2.1.4.16
Satellite RBS50 (3 units)
Firmware: V2.1.4.16
Satellite RBS50Y (1 unit)
Firmware: V2.1.4.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Constant dropping (wired and wireless) with two wireless satellites and one wired
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Daisy chain has to be disabled if your using wired connections between router and satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Answers in bold
What is the Mfr and model# of the IP modem the Orbi is connected to?
Technicolor DPC3216 (from Spectrum in Maine)
~5,000
The one that is hard-wired is 140' away from the router.
Using Auto, will try manual
None
Will try that as well, thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using a different LAN port on the hardwired satellite seems to have calmed the waters. Does it matter which port you use for ethernet backhaul?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really? Wow. Shouldn't matter. So what port were you using and what are you using now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not expecting it to last... but I went from left most to right most ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would also set up a IP address reservation for the satellite(s) ON the router. This could be an issue maybe if there is a IP address conflict with the satellite and another device...
- Mark as New
- Bookmark
- Subscribe
- Permalink
And that's reserved using the satellite MAC address, correct? There's no way to assign a static IP on the satellite as far as I've seen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reserve IP address of the satellite ON the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done, thank you. We'll see how well this performance sticks! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
