- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Constant lag spikes while gaming on PS4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone please him me to resolve this connection issues to my PS4? If not, I will be returning this item to the store. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Constant lag spikes while gaming on PS4
What FW is currently loaded?
Connect the PS via wired LAN cable. Do you see same problem?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#...
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: V2.2.1.210
Modem: Arris TM1602
ISP: Charter/Specturm 400MB
I have not see the same problem with my router
My house is 1999 sqft
The satellite is in my finished basement while the base unit is on the first floor. They are only about 15-20ft away
Channel: 2.4Ghz is Auto and 5Ghz is 48
I can see about 5 other wifi signals
My router was was new so I do not know what the FW was before I upgraded it.
I am currently testing out Port Forwarding on my PS4 hoping it will fix the issue as well/
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also noticed that I couldn’t hard reset my router yesterday when testing other changes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Arris TM1602
This is too close. 30 feet is recommended in between them to begin with depending upon building materials.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe my Daisy Chain was enabled by default once I upgraded. I have most of these others disabled already but I will make sure and test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us now. Also move the satellite farther away from the base as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. You shouldn't need to use any PF if you have uPnP enabled.
Glad something has helped.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Universal Plug n Play auto handles port usage and assignment for devices.
