Discussion stats
  • 2 replies
  • 561 views
  • 1 kudo
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Initiate
Controlling the router/satellite lights
The router and satellite lights indicates the wireless connection quality, which can be nice to know, but it is possible to turn the lights off, or even better during night hours, as they are quite bright and can be disturbing if people sleep nearby.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Highlighted
Guru
Re: Controlling the router/satellite lights
If this is in regards to the top LED on the units, then these should turn OFF automatically after BLUE has been reached.
Review the user manual for top LED behavior.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Apprentice
if your constantly seeing lights you may have to reposition them closer or hardwire the backhaul.
Message 3 of 3
