- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Correct Orbi Router Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thinking of buying Orbi for my house, 2,600 sq ft. Thinking of Orbi BRK50 specifically? Entire house is wired CAT 6 ethernet. Two story house. Two questions.
1. Does the Orbi router module have to be plugged into my Frontier FiOS router and then the from the Orbi into the house ethernet system to drive all the wired wall ports? Or, can I plug the Orbi router into any CAT6 ethernet port in the house? (It would seem logical I could plug into any ethernet port, a port is a port)
2. Will the BRK50 give me better coverage and speed than the BRK40 or BRK30? Will the BRK50 cause interference since it is a 5,000 sq ft model?
Thanks
Need better wifi coverage
Kenny
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Correct Orbi Router Connection
Depend if you want to use the Orbi system as the main host router or if you want to keep the FIOS as your router. If you want to use the Orbi routers as the main router, then it's recommended to bridge this router or use its DMZ for the Orbi router.
If you want to keep the FIOS routers as the main router, you can use the Orbi in AP mode and connect it at any port on your network.
I have a 5000sq ft house and the AC220 router at one end and at Satellite at the far end servicing a PC and a DISH Joey on wireless bridge. Range and Performance has been wonderful inside and outside. ALso have the Satellite running LAN back haul as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Honestly I would avoid Orbi. The system is totally unreliable. Just read the community page and you will read the stories of people spending hours and hours to try to have such an expensive Orbi setup do something very basic like not disconnect every 10min
Avoid at all costs
