- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Currently have Orbi AC3000 RBR50 Plus 1 satellite question on adding 2nd
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I currently have the AC3000 Plus 1 Satellite, I get good reception however I would like to get one more Satellite to hopefully increase bandwith in the house. Which Satellite would be my best option and are they interchangeable?
Thank so much
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Currently have Orbi AC3000 RBR50 Plus 1 satellite question on adding 2nd
All of the original "residential" Orbi satellites are compatible (not "Pro", not "AX", and not the RBS10 model)
My personal pick for "Best Buy" is the RBS40V which Amazon has been selling for $100. (less than any other satellite, and readily available.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great thank you Ill look into that one. I currently have the main Orbi (router) on one side of the house and the satelite and the opposite side of the house. Would putting one in the middle would increase over all bandwith?
I have a Gig going into the router, and have a desktop hardwired to the satellite. When I test the speeds its getting around 300mbs. does that seem normal, and will a 2nd satellite in the middle help boost my speeds?
Thanks again for all your help
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, is it worth getting a WiFi 6 satellite? with my current setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi 6 is not compatible with Wifi 5.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2600sq/ft theres probably 40-50ft between the router and the satellite. Also the router is upstairs and the satellite is downstairs.
Thanks again for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would review this to see if you can help tune your current system. https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Your current system with 1 RBS should work well for the size of home you have. I have a 5000sq ft home and use just 1 RBS, though I have an additional RBS if I need one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great!
Thanks again, and Im assuming RBR is the same as RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBR50 and RBS50. RBR is the router and the RBS is the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
so I did everything in the list and my Satellite is still coming in at 360mbs, with a Gig coming in to the router. The Satellite is a good 40 feet away from the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That the speed rate your testing with a wireless device, if so, then thats in the ball park for 5Ghz AC performance which is good. You'll not see anything near 900Mpbs on 5Ghz Wifi. Devices usually cap at around 400-500Mpbs depending upon design and support. Nature of the beast.
- Mark as New
- Bookmark
- Subscribe
- Permalink
oh, Im testing from my desktop which is hardwired into the satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably same. That also depends on the connection rate between the RBS and RBR. Building materials and distance will be a factor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
is there a way to test how good the signal or connection is between the rbr and rbs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
