Orbi WiFi 7 RBE973
Reply
DM200 & Orbi RBR50/ RBS50 - Not Connected
sprstrx
Tutor
I have had a Netgear DM200 modem connected to a Orbi RBR50 for a couple of years and have encountered 0 issues. Yesterday my internet connection dropped and the power led on the DM200 was flashing amber. I restarted the DM200 and Obri multiple times but to no avail.
I reconnected the router provided by my ISP (BT) which confirmed that I still had access to the internet
I re-set the DM200, configured it with my ISP username/ password and confirmed that I was able to access the internet. I then switched the DM200 into Modem only mode.
I proceeded to re-set the Orbi and reconected everything back up - I have a CAT 5E cable connecting the DM200 to the Orbi Router (LAN port on the modem to the Internet port on the modem). Within the Orbi Login page I re-configured the ISP username/ password expecting that this would resolve the problem however, the Orbi still shows that I am not connected to the internet.
All the led's on the modem are green.
The Orbi firmware is V2.5.2.4
As far as I can remember, this follows the exact setup as before.
Help?!
Model: DM200|Broadband High-Speed DSL Modem, RBR50|Orbi AC3000 Tri-band WiFi Router, RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 30
Accepted Solutions
Ha_Ku_Na
Luminary
Re: DM200 & Orbi RBR50/ RBS50 - Not Connected
@Ha_Ku_Na wrote:
@sprstrx wrote:
I have the router provided by my ISP which is what I'm currently using but it's pretty limited in what it can do and can't be used in Modem Only mode
I would use the ISP provided router and connect the RBR to this router.
And if the ISP provided router has WIFI, turn it off.
What type of ISP router you have ?
Could you set a "static-route" there ?
A little picture to better show what I mean.
Doesn't matter if the ISP provided router has limited functionality.
Therfore you have the ORBI system where you connect all your switches, devices, ...
The IP addresses can change, adapt it accordingly
Message 23 of 30
All Replies
vajim
Master
Orbi firmware?
Message 2 of 30
sprstrx
Tutor
V2.5.2.4
Message 3 of 30
vajim
Master
you're running 2 routers?
Message 4 of 30
BoilerPlate
Apprentice
Wow, and Again NOT a firmware issue. Imaging that.
Message 5 of 30
sprstrx
Tutor
only the one, the DM200 is in modem only mode
Message 6 of 30
vajim
Master
The hottest subject in this forum.
Message 7 of 30
vajim
Master
ok...but it does has a built in wifi ability?  Might want to check with @Ha_Ku_Na
Message 8 of 30
Guru
What happens if you remove the ISP log in from the RBR and set DHCP on the RBR and apply the setting. Power OFF both ISP Modem and RBR for 30 seconds then back ON?
Help?!
Message 9 of 30
sprstrx
Tutor
@FURRYe38 that has had no effect 😞
I'm currently in the process of manually updating the firmware to 2.7.2.104
Message 10 of 30
Guru
Ok, I would try setting the modem back to router mode. then after you get FW updated, set the RBR for router mode as well. Set your modems DMZ for the IP address given to the RBR and see if the RBR connects then. If so, You might try back to modem only mode with the modem and set the RBR up for the ISP account. I'd contact the ISP to ensure the account information is correct and the configuration is correct on the RBR for the ISP account. There many something else that is needed from the ISP for the RBR to connect correctly.
Message 11 of 30
sprstrx
Tutor
RBR FW updated to 2.7.2.104 and DM200 FW updated to 1.0.0.66
Still can't get the RBR to connect. Spoke to the ISP again and they confirmed that the ISP username/ pw should be 'bthomehub@btbroadband.com' without a password but if a password is required then 'bt' should be used. I would assume that these are correct as they allow me to connect to the internet via the DM200 in Modem + Router mode.
Again, switched the DM200 back to Modem Only and connect it to the RBR. I now get an "Problem Detecting Internet Connection" message stating the issue to be caused by "1. Your moden was not power cycled during the cabling step" or "The Ethernet cable connecting your modem to your Orbi Router is not fully inserted or inserted in the wrong place"
I've followed the modem power cycling instructions and also checked the ethernet cable is correctly inserted and tried different ethernet cables but continiue to now receive this message
Message 12 of 30
vajim
Master
Message 13 of 30
sprstrx
Tutor
@vajim wrote:
looks like this has been discussed before:
https://community.netgear.com/t5/Orbi/Orbi-set-up-with-DSL-Model/m-p/1919366
thanks @vajim
I have followed that process but still have no luck.
This was how I initially configured my set up in 2019 and it worked fine until a couple of days ago.
I'm inclined to think that there is an issue with the Orbi as the DM200 allows me a access the internet in Modem & Router mode
Message 14 of 30
Guru
So does the Orbi connect using DHCP with the DM modem in router mode at all?
Try swapping LAN cables between the RBR and Modem? CAT 6 is recommended.
Message 15 of 30
sprstrx
Tutor
It did not connect
I have tried tried swapping out the cables but it hasn't made a difference. Unfortunately I only have Cat 5e cables available at the moment but I'll try get hold of a Cat 6 cable tomorrow
Message 16 of 30
Guru
Don't happen to have a prior or different router on hand to test with do you?
Message 17 of 30
vajim
Master
Or better yet a different modem
Message 18 of 30
sprstrx
Tutor
Message 19 of 30
Ha_Ku_Na
Luminary
Message 20 of 30
Guru
If it's got a DMZ, the you can use the DMZ for the RBR...
Message 21 of 30
vajim
Master
I hope we all don't lose sight of the first post when he/she made this statement:
"I have had a Netgear DM200 modem connected to a Orbi RBR50 for a couple of years and have encountered 0 issues. "
Message 22 of 30
Ha_Ku_Na
Luminary
Message 23 of 30
vajim
Master
Just curious.....are we saying in your drawing to put the Orbi in router mode?
Message 24 of 30
Ha_Ku_Na
Luminary
sure
ISP router with static-route, wifi disabled -> ORBI in router mode
That way you can use all features from the ORBI.
Message 25 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 3787 views
  • 7 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
