Orbi WiFi 7 RBE973
Reply
DMZ does not work
crimvo
Follower
DMZ does not work
Hey all,
Just got the Orbi AC3000 RBK50 router mesh network, and so far its great except that DMZ is not working. Port forwarding seems to work, but I would rather manage the firewall for my server using IP Tables, as I have always done, and forwarding to that using DMZ. However even though I have the correct server set in WAN setup for default DMZ server, it is not opening the ports. When attempting to telnet to 22 for instance, I get connection refused, until I add that port to forwarding.
Any ideas would be appreciated.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: DMZ does not work
Is the Orbi system operating in Router or AP mode?
So your using a different DHCP server on the same network?
Message 2 of 4
Blanca_O
NETGEAR Moderator
Hi @crimvo
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 3 of 4
ekhalil
Master
@crimvo wrote:
............. When attempting to telnet to 22 for instance, I get connection refused, until I add that port to forwarding.
Are you sure that your ISP modem/router is not the one who blocks the telnet request and not Orbi?
Do you see any input in the Orbi Logs when you try the telnet?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3100 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
