- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Daisy chain order
- Mark as New
- Bookmark
- Subscribe
- Permalink
How does Orbi decide to daisy chain vs star network? I have my satellites set up in a way I wanted them to daisy chain. When I first set them up, they worked that way and now for some reason both satellites are reading off the main router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Advanced Tab/Advanced Settings/Wireless Settings
Try putting the remote RBS out at a farther distance to see if it will connect to the 2nd RBS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Daisy chain order
Daisy Chain is enabled on the RBR?
Try a reboot of the RBR only while leaving the RBS on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most devices pick and choose what signal is best for them. Nothing you can do to change that on Orbi.
Glad the RBS finally connected.
Enjoy.
