Orbi WiFi 7 RBE973
Reply
Deactivate ARMOR trial completely from ORBI APP
libremente
Follower
May 28, 2020: Here is what works
1. Upper left corner of iPhone press home symbol in circle on ORBI APP
2. Menu opens, select security
3. Slide Netgear Armor Enable slider to disable position.
4. Back to main menu select setup router and click reboot at bottom of page
5. After you've lost internet and everything, remove power from ORBI and your modem.
6. Reconnect modem power, and ORBI power
7. Everything should come back up with internet enabled and ARMOR inactive.
Good luck. Nothing seems to work as it could with Netgear. You have to figure it out.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: Deactivate ARMOR trial completely from ORBI APP
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
Message 2 of 3
gjlowe
Thanks for this.  How disruptive.  I have to reboot my entire network to remove a trial feature.  Ugh.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2340 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
