- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dead RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dead RBS50
I have a rbs50, looks like dead now.
1)solid green
2)no network activated
3)no ring light on top
4) can't reset
5) no wifi
So I checked all in mother board of the router, Power suplly is all good, CPU(IPA4019) and QCA8075, but the router can not start properly. I notice a lots of customer of orbi have this problem. I think the cpu is broken or insufficient solder that cause all these.I will change the CPU if i can get one .but now i am still checkeing on main board. can some on give some advice for the problem,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dead RBS50
If this fails then the RBS needs to be replaced:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Try nmrpflash?
Others have had luck with that when tftp didn't work
https://github.com/jclehner/nmrpflash
There are no user changeable parts on Orbi systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
