Orbi WiFi 7 RBE973
Reply
Detecting Ethernet Connections
bramsche
Follower
Hello.
So I have the RBR50 and the Sattelite and they work great.  However, I noticed when I connect my iMac via Ethernet, it longer shows up under the Device list.  Furthermore, when I go into the sattelite's IP address, it doesn't show up under Connected Devices either.
Is there something I am missing or is the device list to manage wireless devices only?  Thanks.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
guzzijason
Apprentice
Re: Detecting Ethernet Connections
There have been bugs with the recent version UI and the connected device list. If your iMac is working OK when directly connected, then I wouldn't worry about what the connected device list displays in the UI. Hopefully, the next software update fixes it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 393 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
