Orbi WiFi 7 RBE973
Reply
Device Text Speed Much Lower than Orbi App Speed
_JW
Follower
Follower
I have just purchased a set of 2-unit RBK50 for a 1400sq.ft apartment. App shows download and upload speeds at 450+Mbps but speed test apps on devices show only 80-100Mbps download and 10-12Mbps upload. Can this be resolved?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Device Text Speed Much Lower than Orbi App Speed
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 4
Guru
one thing to keep in mind, if you're running the speedtestt in the orbi app, it actually hosts the test off the router. so its a hardwired speedtest from router to isp. If you then test with the offical speedtest app, it hosts on your phone and that'd be the wireless speed from ISP------router----device. usually the wireless and device are the bottleneck.
For that testing, @FURRYe38 had good recommendations for checking wireless.
Message 3 of 4
Guru
WiFi Sweet Spots is a good start for mobile devices.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 470 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
