× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 4 replies
  • 1309 views
  • 1 kudo
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Devices Not Connecting To 2.4ghz
My new OrbiRBR40 AC2200 mini router network will not allow my 2.4ghz devices to connect. I can only connect devices to the 5ghz network.
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 5
Highlighted
Guru
Re: Devices Not Connecting To 2.4ghz
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What devices are you connecting to the Orbi? if there supporting of 5Ghz, then thats ok if they connect to 5Ghz...
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 5
Highlighted
Further infomation: I replaced my Nighthawk two weeks ago with the Orbi RBR40 and two satelites. The network is working great and is not the problem. I have a wifi camera and two smart plugs that will only work on a 2.4ghz network and can't see the new wifi. This is where I need help.
Message 3 of 5
Highlighted
Guru
What security modes are you using? Try WPA and TPIK, then try WPA2 and AES only.
Message 4 of 5
Highlighted
Retired_Member
Not applicable
This problem has been discussed here before.  It is usally caused by the limit of the 5G over distances and the fact (as you state) that you device will only go with 2.4
Some of the previous discussions were how to change the name of the SSIDs.  Not sure if that was ever worked out.
What I had to do last year was turned down the power of the 5G signal at the router (not sure if this is still an option) and unplug one of my Sats.  This force the Iphone to go to 2.4.  Did my device setup and then return everything back to normal.
Message 5 of 5
