Orbi WiFi 7 RBE973
Reply
Devices Not Connecting To 2.4ghz
sam2345
Follower
Hi, can anyone tell me, is it possible to chhose 2.4GhZ band to connect to some of the clients? As I have some product which only works with 2.4GhZ
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Devices Not Connecting To 2.4ghz
Devices that only support 2.4Ghz will only connect to the 2.4Ghz radio of the Orbi.
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What WPA security modes are you using? Try WPA and TPIK, then try WPA2 and AES Only.
What devices are you having problems with?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 477 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
