- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Devices connecting to farthest location
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have devices that are connecting to the router but are closer to the satellite and vice versa. They are actually connecting to the weaker of the signals. Is there away to intentionally connect devices to the closer satellite of router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Devices connecting to farthest location
People have suggested various methods to do what you ask. The easiest is to power the device off and then turn it back on. If the signal is enough better from the satellite, then the device should connect there. Orbi has a complicated system for moving devices from router to satellite and back. Orbi has to determine that there enough benefit from the change to do it. In general, the concensus seems to be "if things aren't broke, don't fix them." i.e. if the device seems to be performing as it should, then "so what?"
You can search the forum for words like "force device to connect to".
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
