- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Devices not connecting to satellites RBS20
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a CBR40 with 2 RBS20 Satellites. I have a 2 ROKUs and 1 Amazon Firestick and 1 Amazon express devices that I am attempting to connect to the Satellites. Even those the devices are right next to the satellites they connect to the router which is the other side of the house in one case and on another floor in another case. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Devices not connecting to satellites RBS20
How far away from each other are the satellites and the router?
They need 30ft minimum for roaming to work properly.
And if you're daisy chaining (router----sat-----sat), sometimes they'll connect to a satellite further away because its closer to the primary router. The further away/more daisy chains, add latency/lower speeds. so even though its further away, it might actually be faster/lower latency.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank-You for the information.
One satellite is certainly more than 30 ft away from the router the other is right around 30 ft away.
The satellites are currently daisy chained. I have however in the past seen them configured as hub and spoke.
If there a preferable way for them to be setup?
Each satellite is closer to the router than the other satellite so I was thinking that hub spoke would make more sense but was not sure how to force that configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
to force it you disable daisy chain from within the menu options
- Mark as New
- Bookmark
- Subscribe
- Permalink
The first step of setting up your Orbi Satellite (RBS20) router is to ensure you have access to the internet. If you have had a router before, then you have an ISP or Internet Service Provider gateway UPSers. If you do not, then you should contact your desired ISP and get an internet connection installed in your property.
