- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Devices not switching to satellites after 2.2.1.210 update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Devices not switching to satellites after 2.2.1.210 update
What happens if you reduce the power on the Orbi router from 100% to say 75 or 50%?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I already have the transmit power at 75% for 5g and 50% for 2.4. I tried reducing the 5g to 50% but then my devices that should be connecting to 5G connected to the 2.4 instead. Before the update my devices switched to the satellite perfectly. I have a satellite in my bedroom and when I was in bed at night my phone would switch to the bedroom satellite every time before the update. After the update I did notice that the signal from the router seems to be stronger in the rooms where my satellites are so maybe that's why there not switching. Also devices are connecting to satellites when they should be connecting to the router. My TV is right next to the router but it keeps connecting to the bedroom satellite for some reason..
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Try this. Turn OFF the satellites and test with the router alone at with the power at 100%, then maybe turn on 1 satellite.
Whats the size of your home? Sqft?
- Mark as New
- Bookmark
- Subscribe
- Permalink
House is 2107sf and the satellite is about 33 feet from router. I'm going to do a factory reset and see what happens. I havent changed the configuration of the satellites and router and everything was working good before the update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. I would try with the router alone first and check signal and connections...
Let us know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same problem. The way I fixed it was to reset to factory defaults and set up from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are your satellites switching like they did before the update? The signal is way stronger from the router now which is why I think my devices aren't switching like they use to. The problem is if I turn down my transmit power to 50% for 5g then my devices connect to the 2.4g band because its stronger.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try with the router alone first and check signal and connections...The size of your home maybe too small for having the base router and satellites all running.
Let us know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion to reset the rounter and set it up again from scratch. That also resolved my issue with devices not swithing to the satellite sfter updating firmware to version 2.2.1.210. I did see some devices on the satallite once in awhile, and those were idenitified with unknown for connection type. That also has been resolved by the reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for letting us know. Enjoy.
