- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Different SSID for 2.4 and 5GHz on RBR20
We'd like to set the SSID for 2.4GHz and SSID for 5Ghz to different names. Can't figure out how to do that in the wireless settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Different SSID for 2.4 and 5GHz on RBR20
Setting of separate SSIDs is not officially supported by NG for Orbi systems.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 wrote:Setting of separate SSIDs is not officially supported by NG for Orbi systems.
Understood, which is why I asked on a community board as opposed to contacting Netgear. Can it be done and how?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It can be but is outside the concept of a true mesh system. You may be better off to do a search here for there are a ton of discussions on the subject. Some involve using FTP. One may want ask why do want to do this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I want to echo @Retired_Member. Not only is setting different SSID for 2.4G and 5G not supported in the product setup, but methods people have found to "get around" this restriction by using telnet commands will not necessarily work with future firmware releases. There are literally hundreds of posts on this subject.
Now that the Orbi does have a method to stop broadcasting the 5G SSID (temporarily, one hopes), most of the issues about connecting "smart devices" (with dumb software) have gone away. Users on this forum have found ways to make almost everything work with only a single SSID.
If there is a really serious, important reason why your home WiFi has to have different SSID's by frequency band, then take back the Orbi. Get something else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Why do you want to do this?
I ask because some people request that and then discover that they don't need it because there are other ways to do what they want.
For example, people often ask for separate SSIDs because they want to set up some piece of poorly implemented Internet of Things (IoT) toys.
A lot of people find that this is not essential. They just turn off the 5GHz SSID broadcast while they configure their IoT things.
Here's one recent conversation:
Solved: orbi 20 cannot connect Swann Camera - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try the Orbi and see if it works for you in the intended design first. You may find that it will work. If you have specific 2.4Ghz devices that need connecting, first setup the same SSID and PW used on your prior router system on the Orbi. You can use this same information. Thus making migration to Orbi less of a hassle. For some newer 2.4Ghz only supporting devices, there is a solution on getting them to connect as @michaelkenward suggested. It works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 wrote:Try the Orbi and see if it works for you in the intended design first. You may find that it will work. If you have specific 2.4Ghz devices that need connecting, first setup the same SSID and PW used on your prior router system on the Orbi. You can use this same information. Thus making migration to Orbi less of a hassle. For some newer 2.4Ghz only supporting devices, there is a solution on getting them to connect as @michaelkenward suggested. It works.
what happened to this response..."Setting of separate SSIDs is not officially supported by NG for Orbi systems. "
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What do you mean?
I assume that this is what you are asking about? Hard to tell from the nested quotes in your reply.
Just another user.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I was replying to @FURRYe38 who originally said.."Setting of separate SSIDs is not officially supported by NG for Orbi systems. "
Then he came back with another response with possible options..???.....somewhat confusing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not in the least. Both responses are perfectly accurate and not at all contradictory.
Netgear does not support using two separate SSIDs.
Netgear does support turning off SSID broadcasts.
Where is there a confusion in that?
I suggested disabling the 5 GHz SSID because @SKPnSFP did not explain why they wanted to have two different SSIDs.
My first message explains why I put that idea forward. So I will leave you to read that again if you are interested.
Just another user.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@michaelkenward wrote:
@Retired_Member wrote:I was replying to @FURRYe38 who originally said.."Setting of separate SSIDs is not officially supported by NG for Orbi systems. "
his second response (IMHO) added no value. It was only after others talking different options. Sorry you see it otherwise.. have a nice day please
