- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Different networks on ethernet ports (1 Home - 1 Guest)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I am working to get a home network configured with many IoT and devices that should be segmented from the home network devices. In an effort to keep all of the IoT on the Guest or separate network, I need several wired ethernet ports, for that I was going to have a separate/standalone switch.
My question is can you configure any of the orbi ethernet ports to be on specific and/or different networks (ie Home network or Guest network)?
For example on the router: Can any of these configurations be achived: (a) 1 Guest network ethernet port and 1 Home network ethernet port; (b) all guest network ethernet ports; (c) 1 guest network and wired backhaul ports
For example on mesh node: Can any of these configuation be achived: (a) 1 Guest network ethernet port and 1 Home network ethernet port; (b) all guest network ethernet ports; (c) 1 guest network and 1 wired backhaul connection.
My desired configuration is: (Is this possible?)
Cable Modem -> Orbi Router
Orbi Router -> Ethernet port x (Guest network) -> standalong non-managed switch for IoT (DCHP from guest network from Orbi)
Orbi Router -> Ethernet port y -> Backhaul wired connection to mesh node y
Orbi Router -> Ethernet port z -> Backhaul wired connection to mesh node z
Orbi Mesh Node -> Ethernet port a (wired Backhaul)
-> Ethernet port b (Home Network)
Thanks,
Frank
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Different networks on ethernet ports (1 Home - 1 Guest)
@Frank-NYC wrote:My question is can you configure any of the orbi ethernet ports to be on specific and/or different networks (ie Home network or Guest network)?
Alas, no. All Orbi LAN ports are on the primary network. "Guest" applies only to WiFi.
