- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Trying to disable 2.4 GHz radio on Orbi. The option to uncheck "Enable Wireless Router Radio" under Advanced Setup -> Wireless Settings -> Advanced Wireless Settings (2.4GHz b/g/n) is not there as per 2017-03 topic.
Running in AP mode.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Disabling of any radio on the Orbi is not officially support currently on the Orbi.
There a reason you need to do this?
You can try this if you really need to disable radios:
Theres been mixed results...
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Disable 2.4 GHz radio in AP mode on firmware2.2.1.210
I have one AP utilizing the 2.4 GHz radio for legacy gear on a separate SSID. I want all others to utilize 5 GHz. Will return product and probably move to Netgear Nighthawk X6S EX8000. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good Luck.
