Orbi WiFi 7 RBE973
Reply
Disable 802.1b?
stevefxp
Apprentice
Disable 802.1b?
Hello all,
If I do not have any 802.1b devices how can I disable this support in the Orbi?
Thanks,
Steve
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: Disable 802.1b?
You can't. modes are automatic with Smart Connect and MESH systems. If you don't have any B mode devices then the router probably wont use any resources for it. Nothing to worry about.
Message 2 of 2
All Replies
Guru
Re: Disable 802.1b?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 609 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
