Orbi WiFi 7 RBE973
Reply
Disable boradcast SSID
OzHomer
Initiate
Hi. I am setting up the Orbi RBS20 router (firmware v2.3.5.26) and satellites. I want to hide the network/disable SSID broadcast. On the router login page (www.orbilogon.com; accessed on Mac OS 10.14.6 via Safari v13) ) there is no option under either the BASIC or ADVANCED tabs to enable/disabble SSID (I can only do this for the Guest Network, which I am not setting up). How do I do this for the main wifi network?
Many thanks in advance.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Disable boradcast SSID
This is on the Advanced Tab->Advanced Settings->Wireless Settings
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
OzHomer
Initiate
D’oh!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2188 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
