- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disabling source NAT on Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm considering buying an RBK30 system, but have some specific requirements. Looking at the manual it appears there is no way to disable the source NAT function if using it in router mode. I need the following features:
Ability to reserve DHCP addresses per MAC on both the internal and guest wireless networks, and ability to disable the source NAT function (I have another downstream device doing that).
If not, are there any other Netgear systems that support both of these configurations simultaneously?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disabling source NAT on Orbi
I think the best you can do is run the Orbi in Access Point mode and use your downstream device (or another device) to handle the routing and DHCP server functions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, thanks for the reply... this is what I suspected. I may do exactly that - move those functions and have the Orbi just be an AP, but would be convenient to have that option on the Orbi. For the Netgear folks watching please log this as a feature request 🙂
