Orbi WiFi 7 RBE973
Reply
Disney Circle installed on Orbi Router-Passcode Problems
vannar
I have an orbi router with Disney circle installed on it. I use to be able to login to my Disney circle account on my iPhone.
Now my passcode is not working and when I ask for it to be sent to me, I am not recovering the text.
I would appreciate some help.
Thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System, RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 8
Guru
Re: Disney Circle installed on Orbi Router-Passcode Problems
I would post about this here:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thanks
Message 2 of 8
vannar
Than you for your response, but I have read over several threads and tried everything I can do on my end to fix it.
It seems like most people fix this issue by having a moderator help them and get the passcode from the server.
Thanks again!!
Message 3 of 8
Guru
Please post there and I'm sure someone will help you there.
Message 4 of 8
Blanca_O
NETGEAR Moderator
Hi @vannar
Please check your inbox.
Blanca
Community Team
Message 5 of 8
armandobesa
Same issue here. Tried to verify through passcode but always failed. I kept resending and same code keeps failing?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 6 of 8
Guru
Please post about this in the Circle forum:
Thank you.
Message 7 of 8
Blanca_O
NETGEAR Moderator
Hi @armandobesa
Please PM me your name, email address associated to Disney circle, phone number and device serial number.
Blanca
Community Team
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1356 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
