- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disney Plus connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
All,
within the last week my Orbi Mesh will not allow me to connect to Disney Plus anylonger, all other connectivity is fine to netflix, you tube tv, internet etc...
If i go direct from my Fiber to my PC i can get to Disney plus, but going through the Orbi its not allowing me.
I see that there might be an issue with the Circle and it causing an issue?
Anyone have an answear?
Thanks
Patrick
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disney Plus connection
The issue is with Disney. Someone posted about this not too long ago...they ask same thing...came back and said the issue was corrected by Disney.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did they contact disney or how was it resolved?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe so...I was looking for the post thread but can't find it.
Also do you have Armor or Circle enabled on the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
no armor protection that was free for a year is no longer on and i never had circle
the firmware is V2.5.1.22hardware is RBR40
ISP is metronet fiber using a nokia box
we were watching it less than a week ago just fine, not sure if that is wehn the armor protection ended or not
when i directly connect from my fiber to my PC i can access disney plus just fine so it has something to do with the Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset on the RBR and setup from scratch. Be sure to walk thru the setup wizard and do not enable Armor or Circle once the setup wizard is finished.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, try this, get the IP address if your Disney device on the RBR and input this into the RBRs DMZ, and apply the change. Under Advanced Tab/Setup/WAN Setup. Try the app.
Remove or disable after trying this out.
