Orbi WiFi 7 RBE973
Reply
Disney+ Won't Stream Through Orbi Router
Guru
Re: Disney+ Won't Stream Through Orbi Router
Are you wired or wireless when using these apps?
Message 51 of 52
sandthipe
I was having the same issue with a Netgear Nighthawk MR60 Mesh router. I was able to resolve the problem by using Cloudflare's DNS for IPv4 and IPv6. This will probably work with other custom DNS providers like Google or OpenDNS. Cloudflare DNS info: https://1.1.1.1/dns/
IPv4
  • Setup -> Internet Setup
  • scroll to DNS section and select "Use these DNS Servers"
  • 1.1.1.1 for primary
  • 1.0.0.1 for secondary
  • Apply changes, wait for reboot
IPv6
  • Advanced Setup -> IPv6
  • scroll to DNS section and select "Use these DNS Servers" (depending on your IPv6 "Internet Connection Type" you may not have this option)
  • 2606:4700:4700:0000:0000:0000:0000:1111 for primary
  • 2606:4700:4700:0000:0000:0000:0000:1001 for secondary
I'm not sure why this works, but my guess is that it has something to do with the way certain ISPs use a deprecated method for "converting" IPv4 traffic to IPv6.
Message 52 of 52
Top Contributors
Discussion stats
  • 51 replies
  • 5812 views
  • 4 kudos
  • 10 in conversation
Announcements
Orbi WiFi 7
