- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Do both router and satellite emit wifi signal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do both the router and satellite emit wifi signal or does the router just communicate with the satellite and the satellite alone emits the wifi signal? It seem that the signal near my satellite is much stronger than near my router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@althea wrote:Do both the router and satellite emit wifi signal or does the router just communicate with the satellite and the satellite alone emits the wifi signal? It seem that the signal near my satellite is much stronger than near my router.
Both emit equivalent WiFi signals. At a given distance away, the signal strength should be the same for either one. Walls will reduce the signal, of course.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Do both router and satellite emit wifi signal?
If there is no cable between two, what do you think?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
