Orbi WiFi 7 RBE973
Reply
Does ORBI RBR50 work with GoNetspeed Standard (150 Mbps)
BillYoung
Luminary
FurryE38 or whomever can help answer this question:
We are looking at going to highspeed internet from GoNetspeed.  We are looking at the Standard service, which is 150 Mbps.  So my question is this:  will I have any issue with this upgrade of internet service on my RBR50?
Secondarily, will I have to keep my RBR50 in AP mode?  I realize this is likely to depend on the modem provided by GoNetspeed.
Answers to these questions would be most appreciated.  Thank you in advance.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: Does ORBI RBR50 work with GoNetspeed Standard (150 Mbps)
Depending upon modem, modem only unit is recommended. If you get a gateway modem with built in router then you'll need to look into the following:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Otherwise, speeds will be fine. Mines on a 1Gb/50Mbps ISP service.
Message 2 of 2
All Replies
Guru
Couple of options,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1153 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
