Reply
Does Router reboot Satellites?
MarkC1024
Luminary
Just curious if when you reboot the Router via the GUI, does it also initiate a reboot of the Satellite(s)?
Message 1 of 3
Accepted Solutions
DarrenM
NETGEAR Moderator
Re: Does Router reboot Satellites?
Hello MarkC1024
Yes and no Typically when you reboot it will refresh the connection from the main base to the satellite but it does not power cycle the satellite unit.
DarrenM
Message 2 of 3
All Replies
DarrenM
NETGEAR Moderator
Hello MarkC1024
DarrenM
Message 2 of 3
MarkC1024
Luminary
Thanks for the reply Darren.  Might be something for Engineering to consider as an option-  reboot Router, reboot all
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4364 views
  • 5 kudos
  • 2 in conversation
Announcements
