Reply
Does adding in orbi satellite RBS40 (AC2200) slow down the overall speed of the network?
paperlai
Follower
Hi there
I have the RBK50, however I plan to add the RBS40 as I need to increase the range.
I was wondering if I add this, given that its a star topologu would this slow down the overall system?
(i.e. the other satelitte I already have running at AC3000 will still be able to perform at that speed?)
Just wanted to check that the overall system doesn't run at the speed of the lowest rated satelillite.
Thanks
Lai
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Does adding in orbi satellite RBS40 (AC2200) slow down the overall speed of the network?
Just devices connected to the satellite but there shouldn’t be any speed difference. Satellite is getting the WAN bandwidth from the router and shouldn’t see any drop due to dedicated backhaul channel.\
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1207 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
