Reply
Does anyone else get this problem? Orbi RBR750
zaderraider
Follower
Recently I got an Orbi (RBR750) from Amazon to help extend the network connection in my home. I bought the RBR750 version which came with two satellites. So far it works pretty well, there was only one incident where I believe two satellites were too close to each other which caused a problem where my devices couldn't tell which satellite they should connect to. But overall, the connection speeds are extremely fast and responsive. The problem I'm getting though is with the satellite in my room. It works well most of the time but randomly, maybe once a week, my phone will connect to the router instead of the satellite. If my phone is too far away it'll stop using Wi-Fi entirely and use "LTE". This disconnection only happens for a split second then my phone goes back to being connected to my satellite. I never have to restart it when it does this too, it just fixes itself. Has anyone gotten this problem before, and is there a fix? I know its a minor inconvenience but I worry if I'm on a work presentation meeting it'll do the same thing with my computers.
Also on a side note, does anyone's Orbi randomly light up blue throughout the day (2 or 3 times a day)? The connection isn't affected when it does this and it goes away after 3 or 4 minutes.
Firmware version: V4.6.3.16 (For all devices)
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Does anyone else get this problem? Orbi RBR750
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 264 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
