Orbi WiFi 7 RBE973
Reply
Does each Orbi satellite have to "see" the router?
msfox99
Guide
Hi  - just a question about how the Orbi system works.  Does  each satellite have to be close enough to the router to have a good signial with it, or just close enough to the nearest other satellite?  i.e.  is it kind of  a daisy chain?
Thanks.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Does each Orbi satellite have to "see" the router?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Or you can enable Daisy Chain on the RBR and set your RBS out in a line from each other so they piggy back off each other in a Daisy Chain.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 496 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
