Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does orbi work with skyq
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-10-08
12:54 PM
2018-10-08
12:54 PM
Does orbi actually play well with the skyq router and if so how do you set it up
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-10-08
01:00 PM
2018-10-08
01:00 PM
Re: Does orbi work with skyq
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Message 2 of 2
Announcements
