Reply
Does restart the orbi router frequently help to improve internet speed?
Hi,
Just want to ask if frequently reboot the orbi RBK40 help to improve internet speed?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 2
Accepted Solutions
Guru
Re: Does restart the orbi router frequently help to improve internet speed?
Routers shouldn't need frequent reboots. If they do, usually means there is a problem.
My Setup (Cable 1Gbps/50Mbps)>CM1200(LAG Disabled)>RBK853 v3.2.16.22
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
All Replies
Guru
RBK50 v2.7.2.102
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 608 views
  • 0 kudos
  • 2 in conversation
Announcements
