- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does the Orbi team have any plans to allow separate SSID in a patch soon?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm asking since with some of the latest mesh systems like Google Nest to allow it, will Netgear finally give us the option to seperate 2.4ghz and 5ghz as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does the Orbi team have any plans to allow separate SSID in a patch soon?
Very much doubt it. If this is a "deal breaker", I would look elsewhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its not a deal breaker it would be just apreciated since they have fixed ipv6 and made firmware updates not auto update, it only makes since to do this now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you sure Google allows separate bands?
"Your Wifi point(s) keeps it simple by automatically choosing the band that gives you the best Wi-Fi."
https://support.google.com/wifi/answer/6293481
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RedBatman89 wrote:Its not a deal breaker it would be just apreciated since they have fixed ipv6 and made firmware updates not auto update, it only makes since to do this now.
Are you talking about Netgear?
If so, firmware updates with major revisions are still pushed automatically.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well for the lates updates I just saw a notification on the GUI this year it would say update availiable but you had to click to install it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RedBatman89 wrote:Well for the lates updates I just saw a notification on the GUI this year it would say update availiable but you had to click to install it.
True...and those are do NOT contain major revisions. Install at your own risk. Lots of folks in here wished they hadn't
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it is just to set up IoT stuff, you don't need to do that.
Forcing certain devices to connect to 2.4ghz - NETGEAR Communities
