Orbi WiFi 7 RBE973
Reply
Enable Telnet on RBR40 / RBS20 and set Passwords
TMW949
Follower
I am trying to set separate SSIDs for 2.4 and 5 GHz frequencies.  My Nest outdoor camera is literaly a foot away from an RBS20 (with a single pane of glass between them) and keeps promoting itself to 5 GHz and then dropping out.  I need distance, not speed for this camera.
I see the Telnet "hack" to do this but my Orbi firmware (V2.7.4.24) does not seem to have the Enable Telnet option (using 192.168.1.1/debug.htm) anymore.
(1) How do I enable Telnet?
(2) What is the command /syntax to set the password for wla_ssid? Or can it only be the same as the wl_ssid password from the GUI / app?
Please help.  Thanks in advance.
Message 1 of 2
Guru
Re: Enable Telnet on RBR40 / RBS20 and set Passwords
Separation of SSIDs is not supported on any Orbi system.
Telnet was removed from Orbi systems for security reasons.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 551 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
